  2. Check the docs, they're factually correct, unlike ChatGPT: https://www.sidefx.com/docs/houdini/hom/hou/GeometryViewportDisplaySet.html def TintBackface(): node = hou.pwd() bTintBackface = node.parm("tintbackface").evalAsInt() # Get a reference to the geometry viewer pane = hou.ui.curDesktop().paneTabOfType(hou.paneTabType.SceneViewer) # Get the display settings settings = pane.curViewport().settings() # Get the GeometryViewportDisplaySet for objects dispset = settings.displaySet(hou.displaySetType.DisplayModel) dispset.showPrimBackfaces(bTintBackface)
  3. Hi everyone, I am running a very quick (takes about 2 minutes to complete) pipeline related survey with some amazing rewards from our sponsors. The survey ends on 11th August, don't miss the chance to steer the future of open-source pipeline tools and win one of the awesome rewards! Details and survey link here: https://tik-manager.com/pipeline-survey/
  4. Hi, to see how it works in attached file create a new button visibility node from tab -> Digital Assets toggle_button_visibility.hipnc
  5. Hey I have two buttons in hda's UI one to 'Start paint' and the other 'Done paint' I want each one to toggle the other visibility so they are not shown together, I been digging around with no success can someone point me for a good tip please thank you
  6. Yesterday
  7. I also don't like to export directly from SOPs. I tend to do all of my work in SOPCreate nodes so that I can see how my geo is being translated into USD before I cache. You should be able to specify the primitive path on the Geo Clip Sequence node. I don't have a hip file on hand but I have made a tutorial that covers a caching + referencing workflow that might be helpful. Scenes can get slow for loads of reasons, even when everything is cached. The main thing you can do to keep things as light as possible is make sure you have no time dependency badges and ideally have proxy geo for everything. If it's a big scene with lots of assets then unloading payloads can help too. Regarding the bgeo cache, you can use that directly in the Geometry Clip Sequence (as long as you're rendering in Houdini/husk). I do that for heavy fluid Sims as you're right it tends to be a smaller file size. I also cover this in the tutorial above. Alternatively for other things I'll treat the bgeo cache as a temporary cache to avoid having to recook things and then save my USD cache from there. You can of course save directly to USD instead of bgeo. Just use a USD Export in sops or USD ROP or File Cache in LOPs. Note that you should only need the Geometry Clip Sequence if you're caching really heavy geo to per frame USD or bgeo files. For most things you can save to a single USD file which is much easier to work with.
  8. Thank you very much, Matt, for your detailed response and explanation. I greatly appreciate your time and insight. I was hoping to understand more about how you structure your scene while keeping the pipeline in mind. I'm planning to use the Component Builder for asset creation, and I’d prefer not to export USD directly from SOPs. From what I’ve read in some forum discussions, exporting USD from SOPs can sometimes result in missing attributes. For that reason, I'm currently using the Geo Clip Sequence node. My goal is to bring all geometry into Solaris and cache it there. However, I’ve encountered an issue with the Geo Clip node: when I save the output, it alters the hierarchy names. I'm not sure how to prevent this so that it matches the hierarchy created by the Component Builder. Any guidance on how to resolve this would be very helpful. If possible, it would be incredibly helpful if you could provide an example file showing the correct workflow. I’ve looked through SideFX documentation and tutorials but haven’t found one that addresses this specific issue within Solaris. Without caching, I've also noticed the scene becomes quite slow during lighting — especially when working with fur or feathers. Additionally, I have a question about caching: after creating a .bgeo cache, is it necessary to generate a separate geometry cache? It seems to create redundant files, and in cases involving fur or feathers, the geometry cache tends to be significantly larger than the .bgeo. The only benefit I’ve seen is that the Geo Clip Sequence loads faster. As mentioned, is there a way to directly generate the final geometry cache without first creating a .bgeo cache? I’d like to avoid repeated caching steps if possible. Thanks again for your help and any advice you can offer!
  9. Last week
  10. FMX HIVE 2022 presentation by Simon Fiedler & Bastian Schiffer
  11. Hey everyone, I have been experimenting with some new ideas & wanted to ask—has anyone tried incorporating AI-generated content into their FX workflows in Houdini? I am talking about things such as using AI-generated textures, noise patterns or even animation cues as part of simulations or procedural setups. Also I checked out a Gen ai course that briefly discussed how AI tools can be used in creative production & it sparked a few ideas. I want to know if anyone here has used AI outputs to drive things such as pyro, particles or other FX elements. Not just for quick concepts but as a core part of the workflow. I want to hear if any of you have tested this kind of mix. Did it actually help or just complicate things? Maybe someone’s even built tools around this idea? Thank you....:)
  12. Hey magicians, I was following Pizola's guided sim tutorial, and I don't know why my pieces are not falling down. The ghosted box is used as a guide velocity. I have uploaded the file here... Another problem is that small pieces are sticking to the surface area. Playblast1.mp4 GuidedRBD_Upload.hip
  13. 2025-03-1422-12-16.mp4.e555422f6dfe2821d968424cac091851.mp4 I have been looking for this tutorial, does anyone know who makes it? John Kunz? It explains how they added ripples post sim. If you know the tutorial please send me! Thanks
  14. I remember there was a tutorial on this. Do you have the link to the artist that originally posted this? Thanks
  15. I remember there was a tutorial on this. Do you have the link to the artist that originally posted this? Thanks
  16. I don't know your pipeline so I can only comment on why your scenefile doesn't currently work. If you're intent is to sublayer deforming meshes over static meshes then your deforming meshes layer must be authored such that the mesh prims are in the correct place. Your scene attempts to sublayer /Anim/Ball_Anim over /Anim/Ball/geo/Ball, so it won't work. You could reference the deformation onto /Anim/Ball/geo/Ball but your deformation layer has /Anim/Ball_Anim specified as an "over" not a "define" so that won't work either. Essentially you need to reauthor your GeoClip layer. The red nodes in the image here are what I needed to do to make it work. My recommendation would be to either author your deforming mesh with a heirarchy that matches your asset (/Ball/geo/Ball) or your shot (/Anim/Ball/geo/Ball). In the former case you can sublayer the animation over the asset and then reference the animating asset into the shot. In the latter case you can simply sublayer the animation over the shot. Hope that helps. As a side note, I try to avoid sublayering after referencing as it leads to more layers on disk than necessary. If you look at the layers panel, every time you end up with an implicit layer sandwiched between explicit or "don't save" layers you'll end up with an extra layer needing to be saved. So try to order things to keep implicit layers together at the top of the stack so they nicely collaspe into a single work layer when you export.
  17. For anyone else stumbling on this years later I had the same issue today. If you have your Karma render settings "Velocity Blur" parameter set to "Velocity Blur" or "Accelleration Blur" it won't render any Deformation Blur unless you set your deforming mesh prim to "No Velocity Blur" with a Render Geometry Settings LOP.
  18. If you want to import camera into Solaris from OBJ context use Scene Import (Camera) from tab menu. From my experience it imports camera with all animated hierarchy. Or you can first bake all camera animations into a new camera with Bake Animation ROP then import this camera into LOP context.
  19. I have a camera in SOPs, animated with two Null controls. Normally, I'd bake the camera and bring it into Solaris, but currently, baking misses the aim animation from the Null controls. How can I fix this? Ultimately, I just want to bring the animated camera object (controlled by the Nulls) into Solaris. Looking for a quick, easy way to do this!
  20. Use divide-> compute dual on the mesh then convert to lines
  21. If you are not rendering with cpu, just delete redshift-core-cpu-vc140.dl from the Redshift folder.
  22. Earlier
  23. Hello everyone, Hope someone has some insight on how to fix this error. While submitting to my local box, to i get this error Not sure what to do or what this means. Any suggestions would be helpful.
  24. Apologies @vicvvsh I missed your post. This is even perfect. So simple and fast to work with. Thank you!
  25. The issue likely stems from how the proxy is exported — it’s being treated as a single mesh without preserving per-component hierarchy. To fix this: In SOPs, ensure each component has a unique path or name attribute (use Name SOP or Attribute Create). In the Redshift Proxy Output SOP, disable "Export as Packed Primitives" to avoid flattening the geometry. In Solaris, when using the Redshift Proxy LOP, set it to "Load as Reference" and confirm that hierarchy is preserved in the Scene Graph Tree. Each component should appear as a separate prim. Once you have separate prims, use Material Library LOP and Material Assign LOP to assign materials to individual components. If the proxy continues to load as a single mesh, consider exporting as USD with proper hierarchy and assigning Redshift materials directly in Solaris for more flexibility. Hope this helps! forward proxy
