  2. Hi could anyone help me with this expression that I use in Geometry ROP node in OUT context? basically I just need to look for /light/ in the string and if it`s there replace it with /fx/ Here`s what my expression looks now. and If I save hiop somewhere else expression breaks `strreplace(strreplace($HIP, houdini/hip, cache), P:, V:)`/cache_001.$F4.bgeo.sc V:/project/sequences/201/201_0020/fx/work/cache/cache_001.0957.bgeo.sc $HIP - P:/project/sequences/201/201_0020/fx/work/houdini/hip $HIP(in lighting) - P:/project/sequences/201/201_0020/light/work/houdini/hip look for /light/ if there is no /light/ in the string do nothing else replace with /fx/ Thanks a lot Janis
  3. hscript expression, Change the string
  4. Houdini 19 Wishlist
  5. nail polish texture
  6. Houdini 19 Wishlist
  7. Today
  8. Solver SOP Prev_Frame problem
  9. nail polish texture
  10. Tried everything but cant make it work so it would be great if someone can edit the file i upload. Basically i would like to be able to use material fracture + cluster sop but also able to cluster individual objects together and have intra cluster and cluster to cluster groups output.
  11. Crowd Agents Bundle
  12. Polybevel issue
  13. nail polish texture
  14. i see. how about just creating those "missing" constraints yourself, merging them with the ones coming from the material fracture?
  15. I see, yes Voronoi has that option but i am using material fracture sop in the scene and it does not so i kind of need a manuel solution for this
  16. not sure if that option exists in other versions but in 17.5 it's at the bottom of the voronoi fracture
  17. Solver SOP Prev_Frame problem
  18. not looking at your file but it sounds like you want to set Connectivity Partition to None
  19. CROWDS : Walking over other agents / Constraint Network
    Hi, have you read this topic?
  20. Hi Everyone, I'm a student and I'm working on a project in which I need to recreate a scene similar to a Venice's canal. So I'll have buldings on both sides and water between them. There will be also a flying object that will fall and collide with water. This is the first time I work with water inside Houdini. What I need to know is what is the best workflow? I'll create a custom geometry in Maya for the container of the water, it will be an irregular shape. How do I set it as a container? Since there will be a collision, I think the best solution for water is to use FLIP fluids, right? Also if I use this way I will have many particles, so what is the best way to proceed in terms of memory, simulation and rendering? Attached you can find a really rough sketch of the idea. Thanks in advance.
  21. Hey guys, I am trying to cluster some individual objects together but cant get it working could you check? Clustering works within individual objects but does not create connection between different objects ı want the pieces look just like the seperate colored areas. thanks! ClusterTogetherProblem.hip
  22. Polybevel issue
    Hello everyone! I have an issue and can't figure it out.. I want to bevel these orange lines by using polybevel, but insted it seperates in 3 lines. Please, can you help me to understanf what went wrong? Thanks. spiral2.hip
  23. CROWDS : Walking over other agents / Constraint Network
    Any idea of how to make this dynamic constraint creation setup works ?
  24. EDIT : wrong answer :-)
  25. I have a switch with some inputs. Swtich input is linked to $F to loop through. For all of the inputs I created a detail attribute "type" e.g. "sphere" / "torus" / "box". The null node reads the detail attribute and writes the value in its parameter. I want to setup the rendering in a way that it will skip the render if the null node detects that I am rendering a "box". I thought of doing that with a pre frame script that checks the parameter of the null node if its == "box" and then skip the render. What would be the best way to skip the render here? Is there a hscript or python expression for that? Jon skipFramesByAttributeValue.hip
  26. Can't Get Rid of Particle Stepping
    it's always a good idea to set the frame rate of the timeline to something low and check what is going on in those subframes.
