Also the reason I have chosen to separate the ACTOR and the rbd sim rather then retiming them together is because im rendering outside of houdini and do not want to have to reimport ACTOR and reconnect all properties.
I think this is a pretty specific use case but may encounter again when dealing with time remapping of simulations. I have a sim that has been retimed a certain way to match with the the Alembic called (ACTOR_SLOWED) essentially creating a cohesive bullettime effect. The issue is that because the sim and the Actor Alembic have been retimed independently, The actor eventually clips through some of the debris later in the sim. I was wondering if there was a way to just push the SIM PTS that are clipping through ACTOR ALEMBIC out or around or even do another collision sim check to get them to react properly without having to change the entire sim. Initial ideas are to do some sort of POPVOP adjustment or using a custom solver to sim the points again with the retime collider (ALEMBIC ACTOR) but don't really know how to go about that. Any help is appreciated thanks. Wall Break.hiplc
Pop Advect By Volume Problems
tamagochy replied to GlennimusPrime's topic in General Houdini Questions
You can detect by volume sample is particles inside volume and advect them -
p2or started following FLIP morph custom forces
pn2648 joined the community
bookaya619 started following Atom
may be temperature channel act as emissive you can check
VAT Dynamic Remeshing appears corrupted in Unreal 5.2
pandapin223 replied to vamuse's topic in Games
this fx is made of pop or flip in houdini ? cuz dynamic remeshing made from pop dose not work properly in UE.- 1 reply
- unreal engine 5
- vat unreal vertex
Labs VAT > Advance > (Allow Exporting Real-Time Data JSON File (Legacy) ON and Support Real-Time Instancing on) Mkaing this Option ON Houdini Will Export data.json file open That and copy bound min max xyz values to ue material instance. this should work properly with niagara.
guonan100 joined the community
GlennimusPrime started following Pop Advect By Volume Problems
With Pop Advect By Volume inside a POPnet, when particles reach the edge of the volume / the volume bounds, they lose all velocity and just stop. I recall seeing a video somewhere of someone who builds a better Pop Advect By Volume node, by diving inside and setting the particle velocity to continue, rather than just hitting zero. Does anyone know the video I'm talking about? I cannot find it anywhere. Or does anyone have any ideas on how to implement this technique?
adamknauer1 replied to adamknauer1's topic in General Houdini Questions
@Shieh3YES! That's the tutorial. Thank you so much -
Siyun joined the community
Data_Man joined the community
arevcuk joined the community
Nurbek joined the community
pip joined the community
Thank you That exactly what am was looking for -
Chatbot??
- pipeline
- automation
(and 3 more)
