LineartLemur joined the community
ElonMusk joined the community
Copy to points after rbd sim
You need a transform with a pivot to do that, there are couple ways however I just try to do what you already set up there. I store both attributes @transform matrix3 + @pivot from packed DOP IO. Then copy it over the "copy to point" result. Re-apply the matrix. File attached pig_copy_to_pts_transform_matrix_vp.hiplc - Last week
Joeleecw joined the community
Debra joined the community
Exactly like this thanks!
- 2 replies
- copytopoints
brantonic joined the community
You could convert those boats as vdb to be use as a colliders. I highly recommend to do some prep work before to them such as convert that geo as convex hull in a static frame, then using point deform to get them back in place. other than that the geo can be use as colliders individually inside dops, or merge them in sops. -
CarlosGuzman started following Intrinsic transforms, matrices and volumes
Yes, this is working... Ok, why it does not work if I set the position in the same wrangle where I define attributes? snippet_move_points_same_aw.hiplc
I have a two-point curve and I need to shift the point's positions towards each other. I am calculating vectors from 2 points and adjusting positions along those vectors. If I do everything in the same wrangle it does not work, but once I move setting a new position to another wrangle it behaves as expected. What is happening? snippet_move_points.hiplc
Mzigaib started following Cache only point transform for deformation
I know this must be a really recurrent topic but I could not find anything on this so here is my question: In SOPs if I have a deforming mesh with no point count change like a character or a water ripple is there a easy way to just save the mesh once and cache only the points positions in different frames like in USD? I thought Alembic could do that but I don't think it does. I tried to do that with vex trying to store all the positions on a detail attribute but for heavy meshes it is really slow. Any ideas on that? Thanks!
- 2
Now with Sky voice (Scarlett Johansson soundalike)
building from patterns very heavy scene
hannes603 replied to Dag's topic in General Houdini Questions
In Out context you candrop Texture Baker node . You can Bake all Kind of Passes Like displacement , bump, diffuse, light , Emission, ao and 1 Million more to UV space of an lower res Mesh. -
Thanks guys! Sorry for this question, do I need to have Unity for Texture Baker?
Bake Megascans Textures to Low res Geo with Texture Baker
