Nicknn joined the community
emad ghaly joined the community
edocatte joined the community
ASHISH29 joined the community
Look into Voronoi Fracture -
xkzx joined the community
Attribute Growth [SOLVED]
Hi there, I'm trying to bake vertex colors applied to a high-res mesh into the same mesh but low-res and both have a principled shader applied to it. For now, no matter what I change in the principled shader or in the bake texture rop, the baked image comes out black. White UV island img attached If I just try baking a simple texture based on the high-res uv space, without transferring to the low-res mesh, a shiny white UV island image is created. I checked "Use Point Color' in the principles shader, applied the shader to the mesh, in the "bake texture" rop, I add the UV object, and check the Surface Unlit Base Color (basecolor) and the image is baked white. How can vertex colors can be properly baked in Houdini? - Earlier
- store data
- panels
- (and 20 more)
- fire
- karma rendering
