  3. Hello! I have recently been offered my FIRST FX job! I am familiar with Maya, and some Max, but this job requires that i use Houdini, so now i am all in! VERY EXCITED!!! I have a scene where i have to make some letters rise from sand. The issue is that i cannot get things to collide correctly. Doing my research i have tried using it as a RBD object, and using a trail sop to computer its velocity, but i still dont see any collisions. I use static object, pointing to a VDB smooth as the proxy geo, and all of the collision detection/mode set to volume, but no collisions still. I set the sim up with an initial state file too. Could that be the issue? When i take away the VDB to polygons and VDB smooth, delete and just run the sim as a regular static object, everything works! But...i get some weird artifacts rendering. What is the best approach to this method in Houdini? Im sure the solution is just a setting away, but im lost here. Any suggestions? LetterSetup_001_collProbs.hip
  4. Thank you Tesan but I could not make it work... Here is a gif and my hiplc file... mixamo test 1.hiplc
  5. houdini dop inherit velocity
  6. play with this (maybe it's this that you want) Houdini 16 noise.hipnc
  7. post .hip file and someone gonna Play on Cd some noise. Just please post your file
  8. Nature fun
    Birdy DODO L-system
  9. Hi, I need to feed Cd with a noise that will stick to the surface of an imported animated character (fbx or alembic). Thanks for helping!
  10. Toms "Learning Houdini" Gallery
    @Thomas Helzle ok Thanx
  11. For the align topicsmay be you may check this video from entagma : TD Essentials: Parallel Transport. https://vimeo.com/251091418
  12. Toms "Learning Houdini" Gallery
  13. Hey everybody, some weeks I made a simple cave builder and it worked great. But since I only used round circles, it was quite simple. Now I want to create something similar, but with a flat ground, I attached an image what I mean. Actually, I want to align the shape along the TangentU what works perfect, but at the same time on the Y-Axis so that the floor is correct. The other thing is, that it makes no sense when the tunnel has a very steep angel, that ther is a floor - so there I want it based on the angel to become from the floor shape to a round shape. Is it possible, to controll that somehow with a ramp? Thanks alot and happy easter, sant0s
  14. Nature fun
  15. Nature fun
    Homecoming
  16. Toms "Learning Houdini" Gallery
  17. Houdini 18 Wishlist
    Improve hou.Handle class so it can be used to get\set handle orientation\position
  18. Toms "Learning Houdini" Gallery
  19. Zdepth - Extract
  20. VEX Function Source Code
    Thanks, that's good to know.
  21. Fill Selection
    thanks for sharing !
  22. Yesterday
  23. Nature fun
    This is some awesome stuff Tesan, thanks for sharing!
  24. Issue with playback simulation on low ram (32gb) pc
    fair enough that was just my guess at why it was playing up
  25. Issue with playback simulation on low ram (32gb) pc
    32 gigs should not be a problem
  26. Issue with playback simulation on low ram (32gb) pc
    Hi thanks for the quick reply My issue is that when I do cache out my sim as a bgeo.sc, it only caches out the first frame I load So if I first view my scene on frame 1030 and then cache out the sequence, it will save out many copies of frame 1030 I know the data is there though as when I just playback the .sim with a file sop then the whole sequence is there, the issue lies in the playback simulation feature. Thanks:)
  27. I want to get the distance of the radius of a circle to a primitive then apply it back to the circle radius. I'm using the pointDist expression to get a primitive on one mesh, followed by the point on the circle then dividing that based on the channel reference of another circle, but the expression is not evaluating ? ch("../circle1/radx")/pointdist("/obj/file1/polyextrude2/",10,"/obj/file1/circle3/",0,2)
