  2. Perfect it's working ! Thanks
  3. Hey @Lyrops, if you use "return date" insted of "str(date)", it will work. import datetime date = datetime.datetime.now() return date
  4. Simple RBD hanging
  6. Thoughts about this rig?
  7. Hi everyone ! I'm trying to display the date with a font sop using python but I'm a total noob with using python. I've found some pieces of information over odforce but I can't make it work. So far I've manage to make python work inside the font SOP but the lines I'm using sending me "none" instead of giving the date. When I'm using the same script in the Python Shell it works. I feel like I'm missing something important but I don't know what. import datetime date = datetime.datetime.now() str(date) Thanks ! Od_PythonDate.hip
  8. Contract A Rope (Vellum)
  9. Houdini Flip SIMM on a custom wave mesh
  10. Thanks Sergey, just watched the vimeo and it looks really interesting. Thanks for taking the time to upload - I'll be looking to dig through your hip at some point too. Cheers!
  11. Hiya, Thwarted at step 0 of trying to use the crowd pipeline with my custom agents: Trying to use the amazing "agent from FBX feature", but so far, the rig am wrestling with does not export cleanly out of Maya. Given a simple run cycle, I (and much smarter people than I) tried exporting a "nice" FBX to no avail. The joints export fine, animation and all, but for whatever reason the mesh is frozen to a single frame (And that's just reloading the FBX to Maya to check the export). Will keep debugging the Maya side separately (This isn't a Maya forum, last I checked ) Hoping someone here could shed light on a few points: -On the Houdini side, what is the expectation from the FBX file format? how complex is the rig-skin representation? is the skin actually bound to the skeleton, or can they exist side by side? (geo cache and animated skeleton for manipulation by Houdini) -Are there ways to export separately then re-combine in Houdini? (abc for the mesh for instance.. stick to the FBX for the joints) Any help is much appreciated!!
  12. Puddle Crown Splash
  13. Question about increasing Whitewater quality
  14. Thoughts about this rig?
  15. Houdini 18 Wishlist
  16. Simple RBD hanging
  17. Pyro renders taking way too long
  18. Houdini Flip SIMM on a custom wave mesh
  19. Puddle Crown Splash
  20. Preserving ParticleIDs
  21. Particle Systems on Packed Primitives
  22. Tips for Eye Candy Fluid sims
  23. Yesterday
  24. Rendering Cola
  25. Thoughts about this rig?
  26. Rendering Cola
  27. Thoughts about this rig?
