Andre24 joined the community
Vignesh Srinivasan joined the community
theflannel joined the community
Turns out $F should have been ${F}
Lesia joined the community
dmitryfff joined the community
Kareeem joined the community
- 2 replies
- lop import
- instance node
huyng312 joined the community
- 2 replies
- lop import
- instance node
- 2 replies
- lop import
- instance node
Copy to points after rbd sim
You need a transform with a pivot to do that, there are couple ways however I just try to do what you already set up there. I store both attributes @transform matrix3 + @pivot from packed DOP IO. Then copy it over the "copy to point" result. Re-apply the matrix. File attached pig_copy_to_pts_transform_matrix_vp.hiplc - Earlier
