  2. Pro tips for flip meshing?
  3. Align geo with normals on an oval shape
    I finally managed to find a solution : I've separate the circle in two parts : one with the points where I copy my windows, and the other is the original geometry where I want my windows to be aligned with (to do this, just duplicate the circle and double the divisions, and then do a grouprange with an offset and keep the part you want to be the source of the copy (the points in blue are the ones from the original geo and the orange ones are those where I copy the geo)) Then, I compute normals based on the tangent u (with a polyframe sop) from the original geometry and I transfer it to the points I want to copy my windows over, and I rotate my windows by 90 and then boom, it's aligned. I've attached a hipfile because I think my explanations are really non-understandable Cheers, Align_the_windows.hipnc
  5. HELP!! import vdb to houdini
  6. Proper Branching Topology
  7. PolyBevel problem - Modeling
  8. Advice for making paint flow down a wall
  9. Pro tips for flip meshing?
  10. stretch and squeeze by map along geometry
  11. PolyBevel problem - Modeling
  12. Hey, I'm working on a building generator and I can't find a way to align my windows properly when the base shape of the building is oval. When it's a circle everything is okay : But when the shape starts to be oval, it looks like this : Here's the vop network I built to align it with a circle shape, but not functionning with an oval shape : I don't know what I miss to get it working... Cheers,
  13. PolyBevel problem - Modeling
  14. Pro tips for flip meshing?
  15. Hello all, We are relaunching the Seattle Houdini User Group as we have hit critical mass in the Puget Sound region so we can host this events regularly. The first meetup is a smaller get together so feel free to come by if you are in the area. Thanks, - LaidlawFX
  16. Good evening everyone! One problem PolyBevel does not work. Can someone tell me? I can’t get a smooth bevel around the edge. See here that I uploaded a GIF video and also a HIP project. polybevel_voronoi.hip
  17. Vellum Constraint Attributes, what do they all do?
  18. For Each problèm in Houdini 17
  19. lookat Vex function
  20. FOR EACH LOOP metadata
    Thanks, but, I have this "Feedback each iteration" but it output all generations...
  21. Camera Projection from Moving camera
    Hi there, I have been scratching my head about how to project a texture form a moving camera that gradually reveals the footage onto a deforming. Everyting good and easy if the camera is still, but the problem arises becasue this particluar shot has a long back dolly close to the ground so i guess i would need to project all the frames of the said plate onto it. In other words, in frame number 1 you can not see some part of the plate that you can see in frame number 100. How would i need to approach this problem? Mny Thanks Frankie
  22. lookat Vex function
    Hi Antoine, the lookat() function is mainly there to make pigheads stare at spheres. But it might also work on lines ; ) vector pos_target = point(1, 'P', 0); vector pos_geo = getbbox_center(0); matrix3 rot = lookat(pos_geo, pos_target); v@P -= pos_geo; v@P *= rot; v@P += pos_geo; lookat.hipnc
  23. FOR EACH LOOP metadata
    use Feedback mode in Block End / Gather mode. That way, you only output the last generation.
  24. Advice for making paint flow down a wall
    Same I need help with this as well, somehow the liquid is just too thick and I couldn't control it no matter what attribute I adjust.
  25. Большое спасибо, работает!
  26. lookat Vex function
    https://www.sidefx.com/docs/houdini/vex/functions/lookat.html Computes a rotation matrix or angles to orient the z-axis along the vector (to-from) under the transformation. matrix3 lookat(vector from, vector to) matrix3 lookat(vector from, vector to, float roll) matrix3 lookat(vector from, vector to, vector up) Can you explain me how to use this function to have a line along the z axis, anywhere is space, point to another point in space ? I don't understand what the from and to vector are.
  27. Audio channel to controll motion from MotionFX.
    Ah thanks Ikoon. I was afraid I couldn't just pick a frequency for just the drums and voice. Thanks for detailed explanation. I noticed that MOPs actually uses the COPS nods and such. Just installed it, did a small tutorial about it. MOPS seems to give a better overview on the controls from CHOP. So this might work Probably will dive into sonicvisualiser later Thanks again Ikoon t
