SId7565 joined the community
attribute _allen joined the community
DecArt joined the community
Mahesh_Dubey joined the community
10yac joined the community
- lop
- instance node
Copy to points after rbd sim
Exactly like this thanks!
- 2 replies
- carve
You could convert those boats as vdb to be use as a colliders. I highly recommend to do some prep work before to them such as convert that geo as convex hull in a static frame, then using point deform to get them back in place. other than that the geo can be use as colliders individually inside dops, or merge them in sops.
